Ok, so I've been trying to trace this little bugger for a while now and I believe it's time to ask for adult assistance.
The problem is, the right indicators (front and rear) stay illuminated when the ignition is on. I've read through the manual and it says that it should only do that if one bulb is dead, or the relay is bad (or the switch). I think it could be sticking, but I'm not sure. I've taken the relay off the bike and tapped it a few times, but nothing (usually works for any other relays I've come across at work or in cars). The left indicator works perfectly and sometimes when I use the left indicator for a few blinks the switch to the right, the right starts working properly. I'll stop the blinky blinky and after a few seconds, the right indicators will just come back on steady.
This has only happened once before after I rode down a dusty road and parked for an hour or so. Then I went for a brief ride and the indicators went back to normal, so I ignored it. Now my baby has been sitting in my living room for about 5 months and someone apparently spilled some water on Gizmo.. Or put him in bright light... Or fed him after midnight.. Who knows! Either way, this thing is being a pain in my ass.
Anyone have any ideas or encountered this issue before? Many thanks!
*And just for the record, I used the search function and couldn't find anything like this*
