1 - 6 of 6 Posts
Did a short ride just then in the rain on the brutale 920
Went to ride home the electrics turn on as normal and the normal fuel injector noise but it does not stop the electric fuel injector sound?
(edit sorry its a fuel pump noise , keeps going )
Bike wont crank or turn over\ no click noise or anything
no petrol leaking and i have a full tank
never had it before , is it flooded or something weird
checked the electrics are all dry under the seat
checked its not the bike kill switch or the stand sensor ..
have you checked the neutral and or the side stand switch
and fuses
Discussion Starter · #3 ·
and fuses
Yeah took it in and out of neutral, it should fire in neutral even with the stand down but won't, actuated the button the stand uses etc, ill check the fuses in the morning going have to chance leaving it there
ive read a couple of the other people with issues , in the morning ill open the tank and see if i can see petrol ripples (fuel pump tube issue)
where is the sensor for the clutch?, you need to pull that for it to fire even in neutral ill check that too
and ill check the fuses
sigh , hope its just magically fine in the morning
hotsuma;
the clutch switch is on the bottom of the clutch lever mount.....:smoking:
Good call Noel, just had a clutch switch problem, pulled the connector under the clutch lever, bridged them together & it started straight away, touched up connectors with emery paper & contact cleaner, all good now. Try that Reckler.
1 - 6 of 6 Posts
