My bike has been in the garage foe the last 5 days (with the key in the ignition) and I got a day off so I'm going to go for a ride.
I pull her out of the garage, follow normal starting procedure ....
All I get is a very minor attempt of the starter kicking off, just for a second, and then she stops.
I checked the fuses ..... they are ok.
I checked the battery voltage ..... it reads 12.52.
Reading some of the previous posts I see the voltage should be at 13.7?
I'm charging the battery now.
Two questions .....
1. Can leaving the key in the ignition for 5 days discharge the battery?
2. Can I get away with my charger positive cable connected to the battery and the negative cable not connected to the battery? There is not enough room to connect the negative cable of the charger to the battery so I just connected to part of the frame.
Two questions .....
