1 - 11 of 11 Posts
iv just fitted a new battery on my f4 lights and horn work but main panel will not light up and bike won't start help :bawling:
Brendan, It sounds like you have hooked the battery in with reverse polarity.
There are many people that have done this.
The battery is supposed to be installed with the negative terminal facing forward on the bike.
That means the battery is lying on its side.
What year F4 do you have...and where in this world are you?
hi what i though i live in devon gb the battery i fitted was a ttz10s phoned the battery firm thats the only battery for my bike its a 2005 f4
There are many batteries that fit your bike.
The better battery is the Yuasa YTZ10S
These batteries need to be AGM batteries.
DO NOT install a TTz10S on its side.
The battery firm you consulted is wrong.
YTZ10S
Read the small print with the one you have, you might find the CCA is lower than the original, and that it is NOT designed to lie totally on it's side as the original is/was.
1 - 11 of 11 Posts
