1 - 6 of 6 Posts
Hi, I just made a mistake and shorted the battery via the "charging terminal block" under the rear seat on my 2016 F3 800. There sounded like a small click around the battery area and the bike is
now dead. I have checked all the fuses, all good and the battery Shoria Lithium has 13.20 volts across the terminals and from the positive + to the frame. But no screen display when turning on ignition or power to the battery charging terminal plug either. No power to anything!
Is there a circuit breaker or something I have missed. I disconnected the negative terminal from the battery in the hope that it might re-set something when I put it back on, but nothing happened.
Not sure what to do now, any help please.
It is likely that you blew fuse number 8 in the start solenoid. It is a power distribution fuse and it is not in the Fuse Block.
Fuse number 9 is an installed spare and can be swapped to fuse 8.
The location of the Start Solenoid and fuses
I did blow the 30a fuse located on the starter relay, when I replaced it and turned on the ignition the fuel pump powered up and i have power back at the
charging plug. But nothing else, still a dead bike. No dash, no starter, nothing. Thanks for getting me this far, any other possible suggestions please.
Fixed it, removed and replaced the battery leads and the bike started as normal."silentservice703" thanks for your help and spot on advice.
Glad you are sorted.
1 - 6 of 6 Posts
