1 - 16 of 16 Posts
Hi guys, i buy Rizoma grips for my b3 but turns out that I need "ride by wire" one, they send me adapters but all of them are universal, did any one change stock grips and what did You do, tell me You advise/solution what to do, i can always return them but that's not a point.
Tnx
I was looking for Rizoma grips for my F3 but was told they do not make them for MV ride by wire.
If you find the Rizoma grips for ride by wire post it up. I have everything else Rizoma makes for the F3 and would like a set of the grips too.
what the heck is a ride by wire grip? I just bought some $20 grips online, and put them on with hair spray. no issues.
I may have even wrapped em a couple times with electrical tape to thicken them up a little under the grip.
Some, if not all Rizoma grips come with the throttle tubes so they do not work with ride by wire systems...
No :)
The Rizoma don't make adapter for grips who works whit RBW
I will post what i did but 1st i want to be sure is that possible
Not sure what Nenand87s did, but I bought the Rizoma Sportline grips made for Ducati RBW. Part #: GRDW205Z10
Fits perfectly on the throttle side. On the clutch side, there is a little gap since the grip is not as long as the length of bar from the blinker/horn housing.
Do you have a picture of the clutch side how it looks?
I picked up this version of the RBW Rizoma grips yesterday at the shop I always go to. I plan on installing them tomorrow but we did a dry run on a warrantied throttle tube that was of a F3 and the Rizoma throttle tube fits perfectly into the MV setup.
Has anyone any experience with their RBW grips? Possibly came out after this thread was started <img src="http://www.mvagusta.net/forum/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
Rizoma Urlo Ride by Wire grips
Cheers mate thats very helpful!
Sent from my SM-G955F using Tapatalk
Glad it helped. I did not put them on yet. I also got the Rizoma license plate holder to finish off my bike. Was the last Rizoma part for what I needed to complete my bike with all the Rizoma parts they make for the F3 ?
Here are the Rizoma grips on my F3. I suggest you disconnect the throttle cable, lossen up the throttle housing bolts and slide it off the bar. Do not completely take apart the housing so you can use your thumb to keep spring in place
Sorry this took so long for me to post. The grip can go all the way to the signal/horn housing, but then there's a gap on the bar end side. I put the grip closer the bar end to have the same distance as on the throttle side.
Rizoma sells spacers that will close up the gap. You need to go to a Rizoma dealer to get them ordered. The spacers come with their lever guard setup or the adapters for the lever guards or bar end mirrors. I'm going crazy looking for the left over parts that I had which had the spacers and do not recall if it came with lebee guards or the adapters...
1 - 16 of 16 Posts
