I have a 675 B3 and looking to give the rear shock some attention. Obviously there is little in the way of adjustability, being that it is only the spring tension that can be adjusted.
I have noticed that the 800 has an adjustible rear shock....but does it also fit the 675?
Do shocks that fit the F3 also fit the B3?
I find that the standard shock is very spongie.....
I have looked at a few aftermarket options but would be keen to see whether the 800 shock can be run on the 675 (B3) and also whether F3 shocks will also fit.
Take a look at Design Corse. You'll notice the B3 en F3 shocks are in the same group. They will fit.
I like the Bitubo shock XXF 11. :mouthwate
Discussion Starter · #3 ·
Thank you....and does anyone know whether the 800 shock wlll fit the 675?
