301 - 302 of 302 Posts
I've been through this twice. In the end I used tape to hold the rivnut in place. I haven't bothered putting that bit of bling back on yet, this is functional.
Also I didn't want to use the two part epoxy glue because aligning the rivnet to the small panel seems tricky.
If I put the panel back on then the tape won't be visible either.
Reactions: Midnicrow
Wellnut solution that does not involve, rivets or constant replacement of rubber wellness. Also prevents that nagging question, " Are my wellnutz ok?
So I thought why not velcro? So I bought some 3M Dual-Lock and made this. It conserves the integrity of the OEM Airbox in case some collector want to buy your bike. Relatively easy and cheap. If you want the look of the small bolts, you can stick them in and glue to the plastic fascia. The 3M product is very sticky and the Dual Lock is rock solid. I leave for your viewing pleasure. I could have been neater with the installation of the tape. But it works pretty, pretty, good!!
478351
478352
478353
478354
478355
478356
