1 - 20 of 47 Posts
Hi all..
New to the site , Getting my 910r on Saturday but looking at exhaust options, Have a bit of cash left from other bike sales so was looking at the arrow full system with ti or carbon cans
Good price on them so i am tempted , but it says eprom avail for 750 only. Now
If i fit them what are the chances it will make something way off , will it run ok or like a bag o crap. I know some systems will go on without many mods , but others are a pig.
Also will i need to visit a dealer to reset owt, new to MV,s so be gentle
Ta
A lot depends on if you are getting Euro3 spec bike or earlier. o2 sensor on Euro3 bikes makes tuning for exhaust more difficult/expensive. Earlier bikes can easily be remapped with a chip or Power Commander.
Congrats on your new ride. You're gong to love it.
HI mate. Its a 2007/8 model in black with the red stripe..
Would it be best to leave it standard or go for the arrow ?
Does anyone sell eproms that can be used like the ducati 748/916 used to when using open cans. ?
A 2008 Brutale 910r (here in the USA) is Euro3. This means the headers and mid pipe with cat are one piece. There is an ECU (black box) instead of an EPROM (chip). If you remove and replace the stock exhaust you need to deal with the O2 sensor. stuck in the cat area of the pipe. To simply unplug it is a no no since I think this tells the ECU not to allow the bike to be started. So you either need to find an exhaust system with a mount for the O2 sensor or get a Race ECU. With a Race ECU you can remove and toss the O2 sensor. The Race ECU replaces the stock ECU. The ECU is not a chip, but a complete enclosed black box that replaces the stock unit. It is a simple unplug the stock and plug in the Race ECU installation, but requires removal of the fuel tank and air box as the 2008 ECU is located behind the throttle bodies/heads. While you have all this apart you might well also remove the carbon canister (inside fuel tank), the related lines and plug the 4 holes in the cylinder head. This tidies things up, removes a a little weight and gets you another pint of fuel in the tank since the carbon canister is hidden in the fuel tank and takes up volume.
Just a week ago I completed the removal/replacement of the stock exhaust and ECU. I replaced the stock ECU with the Race ECU, removed the carbon canister and related lines and plugged things up. The bike runs MUCH better and this to me was a very worth while mod (new pipe and Race ECU - carbon canister and related lines is simply a cosmetic/tidy thing). The throttle response from idle to 2,000 or 3,000 rpm on the stock bike was snatchy and is now very smooth. On the stock bike there was a surging at 5,000-6,000 rpm. That is now gone. I am very pleased with how the bike runs. It also removed some weight, sounds great and looks better without the fat cat belly. I did not dyno tune the bike. Right now, for me, the programming in the Race ECU seems to work fine. No popping, no hiccups or burps, the bike runs smooth and strong throughout the RPM range. Plus, there is some discussion/debate about whether one can currently use a Power Commander to tune a Euro3 with Race ECU. Although it sounds like one or more vendors is working on something. But again, simply replacing the stock ECU with the Race ECU worked fine for me.
Although I did the exhaust/ECU removal and installation myself, I did take the bike to the dealer to have them check/reset the TPS (throttle position sensor). Following the exhaust/ECU installation the idle changed from 1,400 to 2,200 and the dealer corrected this.
Yes, the exhaust swap is worth while, but be sure you check things about before buying if they bike is set up for Euro3. For me an exhaust and Race ECU was very worthwhile. Race ECU units are available from your dealer or the internet stores such as eMoto and Vesuvio and perhaps others.
By the way, I went with an MV Agusta Corse race exhaust and MV Agusta Corse Race ECU.
I have been through a variety of exhaust mods on my 2008 910R, starting with just Arrow mufflers (sounded great, ran great, looked great, weighed less). No tuning required. My dealer's tech (an ex-AMA race tech with FBF team running MV in 2007) had already tuned the bike for smooth throttle and no surge (there was an updated ECU from MV for the surge).
Next I got a set of FBF race headers, onto which I installed an o2 sensor bung (very easy and inexpensive). Bike still ran good, but I had to install the dB killers in the Arrow mufflers or it was too lean. Still a tad lean with the dB killers, but not bad.
Then I got the MV Corse mufflers...these would not run with the stock ECU...too lean. I bought a race MV "kit" ECU (part number is in the parts catalog with the "special kit" exhaust system). I got mine from a forum member, but available from dealer for about $800. Also installed a BMC air cleaner at the same time. Other than idle trim and TPS reset, no tuning done (ala Power Commander). Runs outstanding and VERY fast.
I also pulled the evap can out of the tank. You have to plug the atmospheric vent in the back side of the tank (I used an 8mm vacuum plug from auto supply), run a hose from the cap vent to the pump base, T the vent outlet on pump base to the water drain hose also on the pump base.
I left the hoses from the intake manifolds to their mounts on either side of the bike and bought 6mm vacuum plugs at an auto store to plug where the evap can's hoses had attached. This gives me a very easy access for synchronization tool attachment and is the same as the non-USA non-evap emissions equipped bikes.
Since the race ECU doesn't control the second air relay anymore I also pulled all that plumbing off and capped the inlets on the cylinder head with some more vacuum plugs (12mm) from the auto parts store. A little less weight and complexity. Sealed off the now open wiring connector to prevent moisture entry and allow future return to stock. The o2 sensor is still in the pipe and plugged into the harness, it's just not doing anything.
I may still go for a Power Commander, but don't feel I really need it. Most of these changes have been documented in various threads and in my album.
I would highly recommend the Arrow mufflers as a great place to start while you break in your beauty and get used to her performance....unless you just want to spend ALL the money, in which case I strongly recommend the complete "Special Kit" exhaust from MV in the parts catalog. Titanium and comes with the ECU....Beautiful, sounds great and runs properly...just ask Randarosa. That's whats on his bike.
:drummer::brutale:
Yep.....
This is the system I have on mine, it comes with the chip and is soooooo loud it sounds like a moto GP above 6000 rpm.
Well i phoned the garage up today & the salesman was very good. EVen tho he is,nt an MV dealer he used to be & he said its deffo a 2008 model with the sensor.
I will get it on Saturday & weighup my options. My 999 has a full zard system on it & that is the dogs..........
Just waiting for some carbon to arrive tommorow & i will post some pics. Weather not looking too good & i,m facing a 3 hour ride home & this bike has never seen rain.
Well it probably will on Saturday
Randy has the full Titanium system? That bastard. He bought it with the bush tax cut for the wealthy.
I guess I did Carl.....:stickpoke I'll likely have to give it back soon, but not without a fight. :)
Yesterday, I spent time at our local probate judge......filling out documentation to get my concealed weapon carrying permit.....then I went out a bought another pistol....:wtf: That's actually the truth, but not because of any political changes.
Banned
and which did you choose randy?
a small or large concealed weapon .357Mag .44 .45, 9mm?
?:drummer:
Firearms. Same sad old story. Look up the numbers. Different country, different culture, I guess. :violin:
?:drummer:
Little inexpensive Kel-Tec P-32 .32 cal. 7 shot hip pocket gun. I'm not in any way a gun nut. I own three for personal and residential protection.
And Mike, I agree, it is a cultural difference. Ours is right for me, yours is right for you. No judgement on my part.
(sorry to hijack) back to exhaust systems.
Yessss! Another perfectly good thread hijacked by gun stuff.
Sorry, I couldn't resist.
All I want is the Titanium headers. I wish I could find a set.
Beautiful system Randarosa, I'm a new MV owner as of a week ago (08 910 Brutale) and I'm exhaust shopping. Any issues with yours, or does it work as well as it looks?
Barry
Very light Barry. The blue color is very attractive, in my opinion. The titanium system is a good bit louder, but not obnoxious. I'm old, and my memory is the second thing to go, but I think I paid about $2500 when I bought the system.
I think you are right Randy...at least that was the number I heard tossed about. You got the genuine MV "Special Titanium Exhaust Kit" which includes the race ECU.
Part number# 8000B0630
Probably none left at MV USA....but you never know until your parts guy logs into the dealer web site and checks. They had one race ECU left when I got mine from a fellow forum member. I know cause I had the dealer inquire.
Good luck.
I checked with my dealer, and the Ti full system is no longer available for the Brutale through MV. I found an MV Ti full system at Emoto including the Eprom with shipping for $2986 at the current exchange rate, is that a good deal?
Be careful with them, I see only bad posts about very disappointed people, and yes, that would be a good price, it usually goes for about $3,500-4,000 for the full system. (are you sure is US $?)That's what is on mine.
The price is 1965.99 GBP for the full system including EPROM with shipping, I e-mailed them to verify availability and price. At current exchange it equates to $2938.66.
And yes, I've been reading some posts today, and I see nothing but negative press about them, what am I missing? Do I steer clear of them, opinions, help?
1 - 20 of 47 Posts
