1 - 3 of 3 Posts
I am looking at replacing my standard rear turn signals with led ones on inside the rear seat fairings. Can any one tell me if the standard signals are LEDs or will I need to install resistors?
Thanks in advance
Clay
You have probably have this sorted, but yes, they are led.
But it does not mean you do not have to run resistors on the new ones (depends on whatever are you planing to use). Resistors might be on the original mount.
You may not need any resistors based on the marker relay. most have load balance built in.
1 - 3 of 3 Posts
