1 - 6 of 6 Posts
Up for sale is this 1999 RS250 Cup bike for $6,300.00 or best offer. Looks great and runs even better. This is a track / race 250cc 2 stroke.
The following items are new with 0 track miles:
Top end on left cylinder (right is near new)
Cylinder and head gaskets
Bottom end inspected and in great condition (cases were split for the inspection)
Throttle, clutch and power valve cables
Power valve springs, seals, mounting bolts (hex) and plate bolts (Allen)
Clutch pack and springs
Fuel lines and filter
Vac lines
Carb gaskets
Fairings (Airtech)
2 stage paint - came out very good but a few flaws. Red accents are vinyl.
Rear Q3 tire (front is Q3 also but not new)
Fork oil, seals and dust seals
Fluids (gearbox and brake)
Air filter
Plugs
Seat recovered
Battery
Grips
Probably more that I am forgetting
Power valves are in excellent condition with tight pins. Not original.
Reeds are like new.
The motor is tight as a drum with no air leaks and carbs have been synched. All cables have been properly adjusted including the oil pump and power valves.
It has a Penske 3 way adjustable shock set up for a 160 to 190 pound rider and Woodcraft clip-ons. Arrow exhaust.
I built this for reliability. A lot of the items that have been replaced were still serviceable and are included along with a cylinder (needs re-plate), plugs and a few other bits and pieces. Also have a printed shop manual and use manual.
If you have any questions pm me or call 909.223.6953.
Bike is located in La Verne Ca. I am of course willing to work with the shipper of your choice should you require it.
*Attached Thumbnails
Oh how I would love to have that bike !!!! FUN..!!!
GLWS.....I am currently on a self imposed new bike restriction while I finish the 3 projects already in shop.
1 - 6 of 6 Posts
