1 - 20 of 33 Posts
I have a 910S with the seat off, I read through the other thread but I don't understand the question. Will help if I can though.
Thanks! I'm just trying to find out:
1: Do I need the Diode on the starter relay plug?
2: If yes, what direction should the grey band on the Diode face. (ie: back or front)
Mines an 08. Looks like red fuses under clear plastic caps on each side of the white connector in pics.
Agusta17...can you post a picture?
Kel, did you read my last post in the previous thread?
Well I took some pics but the laptop says windows doesn't recognize the device. Though I've downloaded pics from this camera before. Tried the cell, same result. Restarted computer but thats about all I know to do. Sorry
I just pulled clear caps off. One 40 amp fuse on each side of the white connector in pics in the other thread, nothing else.
yes euro 3. While I'm not familiar with diodes I'm confident there isn't anything else there besides the two wires next to the white connector, one to the battery, one down the left frame plate toward the starter.
Hi Kel,
1: Yes, you need the Diode! I have one on my 910R.
2: Unfortunately, I just saw this topic and I'm not near my bike to look under the seat. Tomorrow I will and see if I can take a picture for you.
Cheers,
Laur.
the plot thickens......
my '08 910R does NOT have the diode (Euro3 '07 in the rest of the World)
:popcorn:
Noel, I had to cut back the outer cover and then remove some more heat shrink wrap before I could see the diode. I have had a look at my 910 ( euro3) and it's not obvious one way or another, but there is a lump in the wiring not far from the same connector. I'm not game to cut it open unless I have to...
Rich;
double checked......
no diode wires
and the wires in the foreground in your picture are reversed on my bike the yellow/orange is on the left toward the front of the bike
Chuck sent you a picture of it
My screen colors must be off...I see Yellow/Blue...I see Green/Yellow....both on left.
I see Orange/Black ... on right.
Diode between.
1 - 20 of 33 Posts
