Don't think there are too many new ones that are not costly. But the old 2 gas machines have been replaced with fancier 4 gas types, so you may find a deal on a used one. Sun makes real good reliable test equipment. An old SnapOn would be good (probably made by Sun).
I did an eBay search and found those too, but haven't used one. Good info and reasonable price. Shop around~!!
Thanks guys. Since I posted tha earlier I've actually already been out and purchased a Gunson Gastester from Halfords for £80. It's very easy to use.
I was surprised at how different the CO reading is between when the bike's idling without and then with the fans running. Anyone know exactly why MV say to do the checking when the fans are running? My level was high, reading 4.6 with fans on, going up to 5.8 when they went off. So I leaned it out a smidge and got it down to 3.6 with fans on and 4.8 when off.
Si
the key to using the gastester is to have the bike to operating temp to get an accurate reading. I'm guessing fans on, indicates the bike is in operating temp range.
One note: be careful and have your probe only sticking into the exhaust slightly, if you put it in deep, the alum probe tube gets really hot and will melt the clear urethane tubing on the tool. Don't ask me how I know! :)
Si
One note on that....reversion pulses in the exhaust will draw clean air in and cause a leaner than actual reading. I put a rag around the outlet with the probe in to try and prevent that. Best method is to make an adapter to thread into the bung in the headers where you get the most accurate reading. That's why it's there....at least on the stock headers.
Back in the 80's we drilled holes in the headers under the engine and installed riv-nuts for the adapters. I have a 4 gang manifold to take readings from each cylinder....with carbs this is essential to get the fuel mixture screws set perfectly.
4% average CO is a good number to shoot for.
gas analyzer?
gas analyzer?
come on join, the modern world folks
a Lambda meter reads in realtime and on the road too
i have this one on my Aprilia;
http://www.rbracing-rsr.com/turbo/dualo2_01.jpg
dual channel for the twin
and the older single channel one like this on my BMW;
http://www.rbracing-rsr.com/turbo/airfuel_single01ps.jpg
setting CO is easy with a Lambda meter because there is a direct relationship between CO and A/F ratio
that said there is no hard and fast rule for what a motor
LIKES at idle...remember how you set idle mixture on a carb?
the motor tells you what it likes
after you get used to using a lambda meter then you add thermocouples in the exhaust too
