No i only found that the fan was pushed against the exhaust manifold then I prefer to prevent, if I can, the problems. I also added two aluminium spacers at the third point on the basement to push the radiators forward for 2 mm.Thanks a lot for the positive feedback.
Did you put a heat protection above the e-motors?
Did you ever have a problem with the motors?
