1 - 18 of 18 Posts
Banned
Uuugh,
Went on the worlds shortest ride the other day. Started my F4 and got a few miles from the house only to have the Battery light illuminate. It flickers at idle but goes on solid when you rev the bike. Stuck my multi meter on the battery (Shorai Lithium) and it gives out 13V when the bike is off but drops to 12 once the bike is started and drops voltage as the RPM's go up.
Where would one start diagnosing this? Is a dead alternator assumed right away or are there other things to look at first?
Any suggestions appreciated.
Or, you could get rid of the lithium and go back to traditional AGM for longevity.
BTW...how many volts on the system when running around 5000 rpm?
Regulator...but also could be just a poor connection....voltage drops in the ground circuit will cause the regulator to back down the charge rate as output amperage rises with rpm.
13 open volts on battery is good. Voltage drops when electrical system is turned on due to system draws (fuel pump, lights etc). Charge system should immediately overcome the draw and voltage should return to near battery open when engine has started, and rise slightly with rpm increase to regulated max.
The voltage should not go down with rpm increase. If voltage initially returned to near battery open when engine started and then drops with rpm increase the regulator is malfunctioning. Ampere test will confirm negative or positive charge rate better than just voltage.
Alternator can be repaired (it is an automotive component after all). See your friendly auto electrical repair shop.
You are dealing with an excited field alternator, so brushes are at play, and the regulator manages output by varying the strength of the field. There is a way to full strength the field to confirm the base alternator (rotor, brushes and stator) is good, There is also a way to test the diode array of the rectifier...thereby eliminating all but the regulator from suspicion....but this is not stuff easily taught in a forum post.
Some older Japanese bikes had a cush drive for their excited field alternators and the drive (bonded rubber coupling) could occasionally shear, so the charge system worked at idle when the rotor would spin properly, but drop with rpm when the coupler began to slip and rotor speed didn't keep up. I don't think MVs have this problem, though, as cush drive is not a bonded rubber affair.
Jason has some great tips on alternator R&R and repair...unfortunately.
Banned
Hey. Thanks for all the good suggestions. I'm starting to suspect a bad ground. I have issues with my turn signals too and I recently did a track day and may have vibrated something loose. Lets hope at least cheap fixes are always more fun than ones with more than 3-4 decimal points in them.
Been busy getting ready for the 4th so have not had a chance to pull the panels off and have a look in depths yet. I'll let you guys know what I find.
voltages?
battery 12.63V
key on 12.21V
idle 14.84V
@4,000 14.84V
measured 5 minutes ago with a Fluke 87 lll
:drummer:
red light district?
my vote: bad grounds
start at the battery with an Ohm meter, neg terminal
touch the engine, starter and alternator, i see 0.01 Ohms or more its a bad connection
the ECU is 'seeing' the not charging, thus the red light
if the regulator isn't 'seeing' battery/system voltage correctly, it won't charge
if the field windings aren't getting the correct voltage from the regulator, it won't charge
the manual has a 7 page explanation if you want more detail
there is a good electrical trouble shooting guide in the back of the service manual
if you suspect the alternator (which i doubt)
call Rick's;
http://ricksmotorsportelectrics.com/
the young lady knows the electrical value across the slip rings if the alternator is good.....they have regulators and diode sets
Banned
Sorry I never came back to this thread. Interestingly I got an e-mail notification of a new message and now it's gone.
In my case the 40A fuse in the charge circuit blew. Since my amp meter only goes up to 10A I could not measure the current draw so I replaced the fuse and all is well now I ran it for quite some time the other day and the fuse never blew.
In my case the fuse was the original the bike was delivered from the factory with. I did a track day that shook up a lot of the electrical components and I was doing a lot of diagnostics with the key on for a turn signal switch that stopped working (reseating the flasher fixed it instantly). I think when the battery needed to charge a massive amount it was too much for the 11 year old fuse to handle. That's what I hope at least. :)
Noel. Some really good ideas there. I'm planning on doing some cleaning and other service work soon so I may actually go over your diagnostics just to be sure once I strip all the bodywork off. Finding out that I was wrong being a long distance away would suck. :)
Banned
Some photos in case the original poster returns.
Blown Fuse.
Here's where the fuse lives on the left side of the bike.
Here's the assembly pulled out. The fuses are on the back and under white translucent plastic covers. One is a spare. The other is the actual fuse.
Nice photos! It will be interesting if it was just a momentary thing, or if there is an underlying issue....
Banned
Thanks.
I probably will find out soonish. I still plan on doing some digging to make sure when I have some more time. I honestly expected the fuse to blow right away but it's been holding fine.
dielectric grease
rchase;
get some dielectric grease put it on every electrical connection,
fuses, everything
i live 3 blocks from the Pacific Ocean......everything corrodes
when i got my Aprilia RSVR in '03 i took it apart and did the dielectric grease thing.....
no issues yet
:drummer:
Banned
rchase;
fuses, everything
no issues yet
:drummer:
Probably not a bad idea. I'm in the deep south. It's so humid outside tonight I could probably save some money and take a shower outside with a bar of soap just with the humid air. I'm sure that's absolutely GREAT for electronic stuff.
On the Dielectric grease. How is it that you actually apply that stuff? Are you using it around the connector or on the actual pins. I was under the impression that a dielectric was non conductive.
http://en.wikipedia.org/wiki/Silicone_grease
From the Wikipedia article
" It is not recommended to be applied to the actual electrical conductive contacts of the connector because it could interfere with the electrical signals passing through the connector in cases where the contact pressure is very low."
Perhaps a stupid question but one I have wondered about that a few times. The term dielectric is used in other parts of electrical technology such as the insulating barrier between the plates of a capacitor. But hell. If it works I don't care what it does. :)
Banned
Discussion Starter #16
rchase;
you have humidity.....i have salt laden air
here's Permatex's answer;
http://www.permatex.com/products/product-categories/specialized-maintenance-repair/electrical-system-maintenance/permatex-dielectric-tune-up-grease-detail
i put it on the pins and fill the female sockets....
and have no electrical issues
:drummer:
Always sweaty here. Track days in Alabama are great too when it's only 80 out but the humidity makes you completely soaking wet in your leathers.
I'll give it a try. Certainly worth a shot. Wonder how well that stuff would work on the match made in hell of Bosch and Lucas parts in my Rover. On second thought. All those brittle looking wires scare me. I think I'll leave that for another project. :)
Banned
Discussion Starter #18
A Brit car and an Italian bike, you better buy something German to make sure you have working vehicle at available....
LOL. Already have that covered. I started with German cars (Mercedes and Porsche) and Japanese bikes (Yamawhores) and then wanted more excitement in my life. German cars do still break though. They just tend to not do it in such a catastrophic and flamboyant way.
1 - 18 of 18 Posts
