1 - 2 of 2 Posts
Please go the other thread of similar heading, this one is under construction.
DOWNLOAD THE WORKSHOP ENGINE AND CHASSIS MANUALS FOR YOU BIKE HERE !!!
********** http://www.teamdouble3racing.com/manuals.php:yo:**********
********** http://my.agusta.us/**********
MV Agusta Manufacturing List - What they built, when they built it.
************http://www.motorcyclespecs.co.za/bikes/mv agusta.htm************
Beware !!!
Some MV Batteries go in on their side. Take note of the polarity BEFORE and AFTER swapping batteries.
1. Shim kits
http://www.ebay.com.au/itm/321417530217?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT&rmvSB=true
http://zoxoro.com.au/Products/ProX-Racing-Parts-29-748325-7-48mm-x-3-25mm-Valve-Shim-Pack-of-5.html
2.F3 Rear Brake Reservoir relocation (Older F3's only)
http://www.mvagusta.net/forum/showthread.php?t=169289
3. Front wheel bearing sizes - Old and New Models.
Post 2010 B4 and all F4's - 6005-2RS (25x47x12)
Pre 2010 B4 and all F4's - 6907-2RS (35x55x10)
4. Breaking in a modern motorcycle
http://www.mototuneusa.com/break_in_secrets.htm
5. Clic-R Hose Clamps and Pliers
http://www.ebay.com/itm/HOSE-CLIP-PLIERS-CLIC-AND-CLICK-R-TYPE-/191540881349 - http://www.ebay.com/itm/HOSE-CLIP-PLIERS-CLIC-AND-CLICK-R-TYPE/191540881349
Clamps - http://intermark-usa.com/products/other/clic-r/ and http://connect-consumables.co.uk/item.aspx?item=10892
6. Y 10+ F4 and B4 Fuel Tank/line fittings from Aprilia - Item #18
http://www.apriliapartsbuyer.co.uk/parts/pegaso-650-ie-2001-2004/fuel-pump-cpl
http://www.mvagusta.net/forum/showthread.php?t=86362
7. <2010 F4 and B4 Gearbox selector torsion spring alternatives.
http://www.mvagusta.net/forum/showthread.php?t=146794
Will work on some >2010 B4's also, maybe F4's but not sure as yet.
8. Upgraded gear selector spring from 2010 B4, suitable fron F4 anf B4 pre- 2010 also.
12. Most MV's, list updating all the time - Installing heavy duty battery cables, to cure hot start problems.
http://www.mvagusta.net/forum/showthread.php?t=102666
31. Rubber Well Nut Options for ALL models
http://www.desmoparts.com/products/p...bber-well-nuts
http://www.insertsdirect.com/acatalo...duct-Page.html
http://www.probolt-australia.com/wor...bber-nuts.html
http://aerobolt.com.au/products/thre...lb6BoCPTzw_wcB
32. Shim Kit
http://www.hotcamsinc.com/ProductInfo.aspx?item_id=5608
33. Fuel Hose Options.
http://www.calibex.com.au/fuel-hose/...3029D33003D020
http://www.justoffbase.co.uk/Heavy-D...-Sealey-VS1661
34. Fuel Injectors.
http://competitionsystems.co.uk/products.php?pgid=87
1 - 2 of 2 Posts
