Won't work too well on your smokers, Ade !!!
Yeah....I knew that. Had to poke you though... :stickpoke
You really also need to use one with the Bosch wide band lambda sensor, using the std sensor has the display bouncing about all over the place and makes it un-readable
Get one that you have access to the 0-5v output of the AFR, you can then plug it into the laptop using a usb voltage sensor and read/store the data using the diagnostic software....
Oh no, that means another lead Ade Lol...
Adam
