1 - 2 of 2 Posts
Can anyone tell me if the air fillter is re useable can you clean it or do you just buy a replacement, and what is the difference between oil fillters HF204 and HF554 dealer put 10/40 oil in my Brutale and HF204 oil fillter have put the 10/60 oil in but have been sent a HF554 oil filter whats the difference. Have sorted out bike running problems took corce chip out and poped standard chip back in, reset TPS Manualy set CO it was 5% and balanced throtel bodies What a difference . Also discoverd a water pump leak now fixed, and one of the clamps that hold the coil stick in place is missing appart from that bike is fine now.:brutale:
yes,you can ,if it the foam type ,no problems then spray a quick light foam filter oil over it ,squeeze it with your hands and put it back in.Do not over do the filter oil as when the bike heats up it will leak out of the throttle bodies and down your frame.
cheers eddy
1 - 2 of 2 Posts
