mobil mt1-110 filter
fits great!
clears the headers and is tight to the flange.
this is what's going on my mv f4 1000.
alex
just a little update on the mobil filter. i put it on the mv yesterday. it fits, but i couldn't use any of my filter wrenches. i have two that are the right diameter. one is an end cap type which goes on a 3/8" ratchet. the other is a band-type, which works with a wide range of filters. neither would fit because of the clearance to the headers.
so, i put it on hand tight. now, you may think i'm crazy for putting an oil filter on only hand tight, but the spec is for 15 N-m which isn't that much torque. anyway, i did it. took it for a ride and checked the filter for leaks - nothing.
i plan to do something for a wrench - maybe modify the end cap one, or get a strap type. but i will continue to use the mobil filters. the construction is good, and i like the fact that it's bigger so there is more filtering capacity.
alex
