My 2015 TV has the on/off issue some reported. My bike is in for major service. It might be an easy fix but if it's busted i might need to replace the clutch. She's bleeding me dry anyways. :) (Suspension, BDS carrier, ECU, exhaust, tailtidy)
Since i don't know much about clutches i don't know which one would be best for road use. Don't care much for a slipper clutch but don't hate them either. So if buying a new one which one should it be? And what's the difference?
  • TSS
  • STM
  • EVR
  • Something else
Why do you think the clutch needs to be replaced? I put my TC on 1 and am not having the scratchy starts as often when cold.
Are you mechanical? Can you inspect your own clutch? If your clutch is bled and your recalls are up to date then it's most likely your anti-judder spring, warped plates or weak springs... It's not too difficult you just have to have a few tools.
Thanks for your reactions.
I'm not thinking it needs to be replaced i'm just preparing for bad news. If something went sour i want a replacement asap. I have TC off. Things did get a little bit better after i sorted out the low RPM lean fueling.
I thought about pulling it apart but she needs valve checking anyways. Work for the mechanic.
I agree it's probably a plate issue. Don't think it's a hammered drum since that feels different, is more consitent and more a problem when the engine is cold. This is more an issue when the engine is hot.
I just dont want you (or anyone) to shell out money for no reason. These bikes have problems but if all the checks are made and you have to replace a part then go right ahead. But a 100hp TV doesn't need high end clutch. It's not a track bike. Your using the quick shifter 95% of the time and you just want a smooth engagement. I'd fix stock. There's nothing faster than swapping out a worn plate with a plate right next to it if indeed that is a contributing factor.
If your having your valves inspected go with a manual tensioner. He's already in there.
I'm going down the cheapest path.
Which tensioner did you get? I see the 2017+ is 300,- dollar which is quite steep. I also came across a PT900-Pro which is a lot cheaper.
The reason I didnt get a pt900pro is because it has a smaller contact area where the plunger pushes against the chain guide. I bought one from a seller off of ebay that makes them in Utah not China. For you since you live on the other side of the world I'd go with a genuine polaris replacement part.
Thanks, i'm going to check what part is currently fitted. Bike is now off to the suspension guru for some upgrades. I think i'm going for a used automatic (non-hydraulic) B3/4 or F3/4 tensioner.
