Jumped on the site to inspect maintenance manual for my bike & I see that
"article" section is temporarily offline.
Bike is riding poorly @ altitude. :bawling: Would like to know the name of the sensor responsible for this adjustment. Any other thoughts here appreciated!
Check plugs, don't know if you did this with when you tuned your bike but as I mentioned in the other thread the NGK CR9EIX are also a fix for the stalling issue. Give this a try and keep us informed.
Best of luck.
There's a combined air temperature & pressure sensor in the top of the left hand air runner tube - remove the nose fairing and it's at the front next to the headlight assembly.
I would assume that this would lean the mixture at high altitude.
Hi Louise
Are you riding up hotham way. My bike runs a bit off up that way. After a while at that hieght the bike seems to fix itself a friend who is a mechanic said the sensors usually should correct the altitude prob. Maybe the sensor is faulty?
