1 - 11 of 11 Posts
How do you adjust the headlight on the F4? I installed my HID's and need to adjust the low beam up. I heard mention two screws, but can't seem to tell where they are.
Anyone have a photo?
Thanks!
Alex
Thanks!
Alex
Here are some pictures hope these help. Where do you install the HID ballast
Thank you!
On my bike both these bolts were covered in a gob of glue. I didn't realize they were even there. Once I removed the glue - a hex key helped me out..
Just to be sure - left is up and down - right is left and right..
Thanks again,
Alex
actually there is a 3rd screw on the bottom, the bottom is the up and down, and the 2 screws on top, the left and right screws pictured above, u use them the scew the headlight right-up and left-up, its kinda weird, it took me a while to adjust my headlight.
Man - you guys are GOOD!!
So - what exactly do I need to do to RAISE the headlight pattern?
Counter-clockwise on the LEFT Top screw and Clockwise on the LEFT Lower screw?
Thank you again!
Alex
1 - 11 of 11 Posts
