Hola, tengo una f4 1078 312rr 09 y ultimmente presento la falla de que llega aceite a la caja del filtro de aire. Alguien le a pasado? ( 12.000 kms tiene la moto)
"Hello, I have a f4 1078 312rr 09 and lately I present the fault that oil arrives at the air filter box. Has anyone happened to you? (12,000 kms has the motorcycle)"
@Aguayo First, welcome to the family!! Could you please add your location on the planet to your profile?
Oil in the air filter area is coming from the crankcase breather. You have either too much oil in the engine, or excessive crankcase pressure caused by piston ring sealing problems.
High oil level, especially at sustained high rpms, will push oil out the breather.
Check your oil level.
Related Threads
MV Agusta Forum
1M posts
55.7K members
Since 2005
A forum community dedicated to MV Agusta motorcycle owners and enthusiasts. Come join the discussion about troubleshooting, maintenance, performance, modifications, classifieds, and more!
