1 - 20 of 38 Posts
No more questions, here is the definitive answer on Brutale SPU part numbers. It may have been posted elsewhere, but it never hurts to suggest that it be made a sticky or put into the faq section.
If you own a Bruatale made between 2003 and 2008, it does not matter what the part number of your SPU is. There are two SPUs, and only two, which supersede every other number.
If your Brutale has a VIN ending in 100421 or lower the new part number for your SPU is 8A00A9615. If your Brutale has a VIN ending in 100422 or higher, the new part number for your SPU is 8A00A9300.
NB: It doesn't matter if you have a 750 or 910 with a VIN ending in 100422 or higher, it is the same SPU for both bikes.
You're welcome.
100% Verification - 2006 Brutale 910R SPU
You're welcome.
I have corresponded with Andre @ Star Twin asking about the infamous Brutale SPU. He tells me:
"According to the most recent info from MV Agusta, the 8A00A9300 (our reference 0003515) will now fit all Brutale 910,989 and 1078. The 8A00A9615 is only applicable for Brutale 750.
We sell 3 to 5 of these units per month and have no problems anymore."
"Yes, The 8A00A9300 should work, we have only good feedback on these new and improved SPU’s."
Even though my Brute has a VIN lower than 100421.
This is supposedly a new and improved SPU for all 910's -
Is this correct???
wtf????
Is this correct???
But what if I have a 750?
as Carl said;
if your VIN is 100421 or lower the new part number for your SPU is 8A00A9615
if your VIN is 100422 or higher, the new part number for your SPU is 8A00A9300.
it doesn't matter what year or what color your Brutale is, its the VIN that counts......fuck me, how much simpler could Carl have made it:wtf::wtf::wtf::wtf::wtf:
look at your VIN....there's your answer:jerkoff::jerkoff:
as Carl said;
So, what's the correct answer? :wtf: :stickpoke:laughing: :later:
Glenn;
i don't know......Brutale owners have to be smart enough to read their own VINs and figure it out:stickpoke
they have 2 choices:jerkoff::jerkoff::jerkoff:
as Carl said;
Hey Knurl, stop making me laugh my fungin ribs are killing me.
So my VIN ends in 100474 and I have a 750 - I should get the 8A00A9300?? Because earlier in the post it says that the 750 should have the8A00A9615!
Nervous cause I don't want to get the wrong one!
Yup, look again.
The best way to go is by telling the guys you're ordering from, they should know too.
Hi,
Do you know if exist many type of blue back SPU units?? Originaly have blue back SPU the bike....i bought a new one the same blu back and didn't work,everything is fine but the fuel pump not work with it....have you idea?
You have a 2006 910....?? The VIN is the frame number. There are no bad SPUs available from MV anymore.
If you need a new SPU then order one from your dealer for your model. You will get the new part.
The 750 and 910 have different VINs. I believe the sequence Carl posted is 910s. ALL 750's had suspect SPUs but later 910s had improved parts. Your 2006 had suspect SPU. Order the new one for the 910.
1 - 20 of 38 Posts
