Superveloce 800
A question for those of you with a more recent model in relation to the ABS settings:
My Superveloce essentially has two levels of ABS (1 & 2). Logic and convention would seem to suggest that the lower the number, the lower the level of ABS intervention, thus Level 1 would be more appropriate for the Track and Level 2 for the Road (say).
However when playing around with setting custom maps in the MV Ride App I discovered the following and I am now confused:
One of the options you can set for a custom map is the ABS setting, which is conveniently not listed as “Level 1” or “Level 2” but “Sport” and “Race”. Fair enough I thought, Level 2 is “Sport” and level 1 is “Race” but no. That would be too obvious!! If I set it to “Race” in the app and send the map to the bike then the ABS setting is set to Level 2. If I set it to “Sport” in the app then ABS is set to Level 1?!?!?
WTF!?!
Am I therefore to infer from this that Level 2 is actually less intervention than Level 1?
That seems very counter-intuitive but I can’t see any other explanation...
Perhaps someone could clear this up for me with certainty?
Many thanks!!
Is it that there is an "R" designator that you have associated with Race versus Rain?
(I know the older bikes have "R"ain mode...)
Ah, I see now. There’s not much info out on the SuperVeloce yet.
