1 - 19 of 19 Posts
Today we got together with about 20 other riders for a lovely all day ride. This ride has been in the works for some time and I've really been looking forward to it. I even got new tires and made sure they were broken in and ready.
At the very begining of the ride the person behind me said my bike was smoking when I rolled on the throttle and it was getting worse. Closer inspection showed that it was leaking from the oil filter. My husband had changed the filter several weeks ago and he thought he might not have tightened it enough. Most of the riders felt that it would be okay (just a tiny bit of oil on the back tire, but not enough to matter). So we continued. Got about 10 more miles down the road and the bike was smoking really bad!! My back tire was totally covered in oil (I'm really lucky I didn't go down) and I'd probably dumped nearly a quart of oil.
Luckily we were near my parents house so I told everyone else to go on and my husband and I limped the bike there.
We didn't have the special tool to tighten the filter so my dad (he is very handy) fabricated something. After nearly 5 hours of messing around with tool manufacture the filter was tightened. Only to find out that wasn't the problem the filter had developed a crack in it, that is why it hadn't leaked on my other rides. Has anyone ever had this problem??
do a search on google.....mv agusta oil filter problem...you will get a greenspun site.....same thing happened to me....make sure you got a new filter and not one of the old recalled ones like i did. Same Scenario happeend to me
Do you have the strap on there? I know you got the crack, but I don't think ANYBODY should have an oil filter problem with it unscrewing if you put on the strap....
Pimp of posts
MV Cellist
Christina, very sorry to hear what happened to your bike... after what has happemed to my Senna, I think I can understand your frustration; the good thing is that you are ok, the bike is ok or will be ok, it just requires a little of TLC so it's nice and clean again.
Where did you buy the filter just curious?
I'm not sure what you mean, but I did have the rubber "thing" and the plastic "thing" on the filter. The filter didn't unscrew, we just thought it might have initially.
I haven't read all the threads, I'll have to find out what happened to your Senna, doesn't sound good...
My husband and I spent some time with Simple Green and my bike looks much better! Just some caked on baked on oil under the pipes still.
I got the filter from Pro Italia.
Thanks Matty I'll have to check that out. Sorry you had a problem to, but I'm glad to hear that it can happen and it isn't some worse problem with my bike!
odonata said:
a crack in the filter, could it have been over tightened?
No, it was definitely under tightened if anything. Jeff (my husband) didn't do much past hand tightening. Possibly the filter could have been damaged by the tool he used to tighten it (not the stock tool), but I doubt it, he is really over cautious with such things, especially on my bike. If I so much as try and leave the driveway with 1 psi to few in my tires he stops me and fixes it.
But anything is possible. I guess the only way to find out if it was the filters fault is to replace the filter (making sure its the correct one) and see if it happens again!
Yamaha R6 filters will fit, and I use the K&N with the drilled nut on the end.
Better filter, and FAR easier to install and remove.
MV Cellist
I hope you still have the cracked filter... bring it to PI and see what their mechs have to say about that, I wonder if they can offer any advices or explanations.
When you use the Yamaha R6 filter, do you use the retaining ring as well? Also, is there a Mobil One equivalent that anyone has seen?
Discussion Starter #17
The filter is black, and it came with the safety ring and rubber sleeve. I don't have pics because the bike is still up at my folks house, I've been out of town all week, unable to fix it.
I don't ever remember hitting a rock or anything, but could something like that crack the filter?
Does anyone have the official "tool" for filter removal, if so, does one have to remove the pipes. The tool shown on Pro Italia's site doesn't look like it would fit without removing the pipes.
I'll have to look into the Yamaha R6 filter, thanks for the info!
Christina
The stock tool I bought from Pro Italia wouldn't go onto my filtr so I used a band tool. Fazer, I really like the R6 w/nut and safety wire. Very nice and my next choice.
Discussion Starter #19
I went to Pro Italia today and got a new oil filter (wanted to get K&N yamaha r6 but no one open on Sunday carried it). The tool my father made specially for the Brute filter worked perfectly! (I'll have to attach pics as soon as I can). We got the old filter off and the new one on without having to remove pipes and with little or no swearing! The 40 mile ride home showed no leaking. Hopefully it was a one time thing!
I told Pro Italia about the crack and they really couldn't have cared less... I didn't have the filter with me (it was still on the bike in Greenvalley) probably just a fluke!
Thanks for all the info,
Christina
1 - 19 of 19 Posts
