1 - 6 of 6 Posts
as long as the mounting points are the same you should be okay. The plumbing, if it is different can be fixed
990r has the euro 3 models type radiator with two fans and no mounting hole for temp. sensor, so you have to machine one. Also needs some mod. to the fans wiring to match it with the main wiring on the bike.
The mounting points should be the same.
Cheers,
Laur.
1 - 6 of 6 Posts
