1 - 3 of 3 Posts
I need some things for my 989R
A rear Hugger
To get rid of that massive "box" thing that is apparently an exhaust.
I like the stock cans tho, so what do I need to do..
bear in mind, I aint exactly Richie McRich, so I'd rather this be on the "cheaper" side if possible please.
The "Box" is the catalytic converter....you need new headers and a mid-pipe. But your system will require the o2 sensor, so you will need to weld a bung for that into the mid-pipe.
Your headers are welded to the Cat in one piece. The pre-Euro3 spec bikes have the pipes you need...just add the o2 sensor mount. CAG may be able to help you with used parts.
1 - 3 of 3 Posts
