1 - 12 of 12 Posts
This shows the difference from a stock 04 750 Brutale against a stock 910.
Purely for educational purposes only. :blah:
Black lines are the 910, red lines are the 750
MV Cellist
Great, thanks for posting. how about the curves for your R ? is it much different from the standard 910?
It would be nice to get the data for stock F4 750, 750SPR, 1000, 1000R/Senna, Tamburini, done with the same Dyno/operator, just to have it on file here @the forum... :naughty: :conveyer: :conveyer: :conveyer:
That was my R and both had the fueling pretty good with PC's
I'll have a 910S in this weekend but it has a midpipe fitted.
The R is suppose to have just 1.5hp increase over standard because of the head porting but gains 8 or so hp with the race exhaust and chip.
When they come in, I'll post results of all the different combinations, and I'll be able to see exactly what the chip does. :conveyer:
John T
Thanks for posting, also installed the mid-pipe on my 910s, but hedging on the Power commander this would help motivate my decision, also it that rear wheel readings?
Cheers Michael
Mine is...I'm assuming the others are as well.
When I asked the guy about the PC3, he said it won't give but maybe 1HP, but the important part is your A/F ratio in ALL RPMS and ALL throttle positions. Crisp smooth throttle response.
Exactly! This is precisely why I am asking John to install and map the PC on my 910. I want to get rid of that nasty on/off throttle transition and improve the gas mileage.
anucci said:
gas mileage.
That's my MAIN reason for getting a PC3, as I know what you're talking about for the throttle response, but it's STILL smoother than most all other bikes on the road....anything I can do to get the 750's gas mileage up, I'm doing :laughing:
I have never ridden the 750, but I think the 910 may suffer from the off-on throttle transition jerkiness more than the 750.
I have finsihed with the fine tuning / TPS reset and throttle body synch on my 750 Brutale after installing a Moto One MVB02 Eprom chip. All I can say is WOW - the smoothness from right down low is amazing and the fuel range mileage jumped from 80miles to reserve light to 115miles. I can hum around in traffic at 3000rpm in top gear and pull away cleanly.
I am amazed at the difference from when I had just a PCIII USB initially. My Dyno run was 108.3 with only midpipe, BMC air filter and eprom, not startling, but respectable.
I pulled the PCIII off the bike and sold it off on Ebay, seemed no sense in doubling up, when the eprom did the whole job anyway - I was running a zero map until I knew that things were right.
All I can say, is that proper TPS and throttle body synch is vitally important.
the on/off jerkyness was gone once john did the custom map on the Power Commander with my bike. It was a whole new beast once that was gone. :smoking:
1 - 12 of 12 Posts
