Hi, I'm doing a valve clearance check at 53,000kms and have the cams, buckets and shims out. The Engine Manual formula at Section B p. 43 reads:
C) Calculate the D difference between the compared play and optimal play shown on the chart [see valve play specs];
D) Read the value of S thickness on the tablet;
E) Choose new tablet/shim with an S+D thickness
Inlet upper spec: 0.24mm
Measured Valve play/clearance: 0.13mm
Measured present shim thickness is 2.42mm
MV Formula:
Calculated difference between valve clearance and upper value of spec D =0.11mm
Value of thickness marked on the shim S =2.45mm
New shim thickness S+D =2.56mm
This doesn't seem right since my clearance is already below the minimum spec of 0.15mm with the 2.42mm shim and requires a thinner shim in order to widen the valve clearance gap up to the top of the spec.
I've checked my Honda CBR100RR manual and it gives the formula:
Calculate the new shim thickness using the equation
below.
A= (B-C)+D
A: New shim thickness
B: Recorded valve clearance
C: Specified valve clearance
D: Old shim thickness
Using this formula, I get a new shim thickness of 2.31mm.
Many other sources on the net corroborate the Honda formula.
What am I missing with the MV formula?
cheers, Claudio
You subtract the variance from spec from the existing shim thickness.... you want to install a thinner shim to increase clearance. It's just the way you read/interpreted the Italian translation in the manual.
Yes...you need a 2.30 shim (they come in increments of .05) or a 2.35.
OR you can machine the shims to be precise. Go for a clearance that is in between minimum and maximum. Near impossible to get exactly on or the other.
Reactions: claudiop
Thanks for that confirmation.... BTW I'm Italian and native speaker so I checked with the Italian engine manual also. It states...
C) Leggere sulla pastiglia il valore dello spessore S;
Literally, this translates,
C) Read on the tablet [shim] the value of the thickness S
I don't know how else it could be interpreted.
Still, thanks for the confirmation, cheers Claudio
Sent from my ASUS_X00QD using Tapatalk
You are not plugging in your numbers correctly.
Calculated difference between valve clearance and upper value of spec D:
.13mm (clearance) - .24mm (upper spec) = -.11mm
New shim thickness S+D:
2.45mm + (-.11mm) = 2.34mm
Or for your measured value:
2.42mm + (-.11mm) = 2.31mm
