1 - 19 of 19 Posts
hey all--
took out my brand new 910s this weekend and found the bike very difficult to ride smoothly. throttle surges were particularly noticable in low gears although i tried my best to keep my inputs smooth. :errr:
i've ridden for years on bmws (r1100s, r1200gs) and found them so much easier to handle. is this a new bike thing? will my mv smooth out as it gets past the break in period? any experience or thoughts would be helpful.
thanks.
I think the problem may be greatly exagerated due to your past experience. No offense intended, but you've been riding bikes w/ a MUCH lower power to weight ratio, w/ non-responsive drive trains, heavy flywheels, and barcalounger suspension.
You're now riding a twitchy little thing w/ a P/W closer to that of a Formula 1 race car and very little rotating mass to counteract throttle changes. That said, the stock throttle does tend to be a little unforgiving. You might try shortshifting it, but the two things that will help most are time and a PCIII.
ramenboy said:
hey all--
thanks.
Maybe mapping problem???Airfuel probaly knows better!!! :smoking:
I've got a Brutale 750 and this week-end one of my friends give me his 910. I confirm the engine of the big one is more difficult low in the turns. The 750 is much more flexible.
Could be a mapping issue. Surging sounds like more than normal responsiveness. It will take some getting used to - but shouldn't be hard to ride.
Try varying your RPMs, in other words, try different gears perhaps than what you're used to. You might want to get more specific with speed and RPMs you're having the trouble. In other words... were you cruising down the freeway? doing 35? Change between off/on during a turn? We might be more help.
You shouldn't need a map or PC. There is a chance the bike is not tuned CO. How many miles? Has it had the 600 miles service?
I think the S I test rode was much more twitchy than my R so they are not all the same.If you do a search there is a spring on the throttle body you can unhook and it will make the pull lighter.
Remember that the Brutale 910 is essentially a full sport bike in naked guise and therefore gives little concesion to "rider friendly". It is horses for courses.
I once brought a new BMW, had it 2 weeks and took it back. It was just too civilised and nice. I brought a hot Ducati instead.
So you will either get to love it or not. It may pay to have some lessons at a track school? Just a thought.
I second the comments regarding CO, past bike experience, and time. The throttle response with the stock mapping is good. Rich, but it should be smooth and not surging.
Suspension is also a factor. MV Agusta suspension is machined to close tolerances and is very tight when new. You'll need 1500 miles or so to really butter up the suspension. Once it's broken in, the smoother ride can help maintain a smoother throttle hand. You might want to set your suspension to full soft for a few hundred miles to get some motion in there till the stiction reduces. However, you will likely find the bike a bit too wallowy and vague if you leave it at full soft and try to ride hard.
The stiff throttle return spring can result in fatigue and less precise throttle control; time in the saddle will rectify this issue.
I've also found that the cold weather this time of year can result in a stiff wrist, cold hands, and consequently, hamfisted throttle control.
Give it time, get the CO/idle checked, and pay attention to all the little things mentioned. I'll be it's mostly your experience with BMWs, though, and the fact that this is a explosively powerful, race-bred, too-much-is-never-enough kind of bike. I've found that even the 1200cc Beemers are pretty soft feeling. Not slow-- deceptively fast, in fact-- but they feel soft and smooth. A Brutale is more like riding a two-stroke motocrosser; that's just the core riding experience.
Yup, massive amounts of torque down low will make for a herky jerky ride if you are hamfisted with the throttle. Bikes with no torque will feel creamy smooth as you are trying to catch up. :moped: :stickpoke
The 910 demands alot from the rider, you will be handsomly rewarded when you are good!!
If your fueling is off, even the barcalounger bikes will fell like crap though.
The snatchyness you feel is only evident if you are trying to ride it slow and smooth like you're trying navigate a MSF course. :)
When in situations where you have to have low speed control just blip and slip or wind it up. :)
Try from an idle in neutral to get the RPMs anywhere between 1300 and 2000 rpm... I bet you can't.
This is what makes mine very hard to ride smoothly as well. The dealer wants $99 for a new chip to "fix" it.
i think thats normal, atleast my MV guys, shop and i experience it too and not much u can do about it but 2 teeth down in the back, It will smooth things out tremendously. Or u can just adapt to a hooligan motard riding style, which will make it feel second nature.
ramenboy said:
hey all--
thanks.
King of the Sink
It's perfectly normal. I'm sure I looked like a complete idiot for the first few weeks on mine. My recommendations would be to make sure you're well above 4,000RPM when you change up, keep the forward momentum going as much as possible, use less clutch than you normally would, and pre-load some tension on the gear lever.
Having said all that, you'll adapt and get used to it pretty quickly.
yeah... what Sven said.
I've only put 1600 miles on mine, and I still feel like an idiot sometimes - especially after returning to the Brutale after spending a few days on my R1200GS. Now that my bike is run in a bit, and when it is fully warmed up, and I'M fully warmed up, the riding experience is smooth and magical.
Agreed, it took some getting used to as the 910 is the snottiest, most angry, little bitch of a motorcycle I have ever ridden. Once you get used to it, its quite a pleasure. I would also reccomend releasing the clutch side, furthest outboard throttle return spring, it allows for more linear throttle delivery as opposed to the on/off switch set up it comes out of the box with.
Discussion Starter #17
Thanks for all your input... this is an awesome forum. Took out my S this weekend and rode like I was pissed off and all was well. Also signing up for California Superbike in March.
Cheers!
Glad to see you guys showing some respect from the 910. It's a lot of bike and the fools who say you aren't riding it unless you're hitting the rev limiter are just letting their pride show through. The bike demands respect and can be difficult to ride to its limits on a fast track, much less the streets.
1 - 19 of 19 Posts
