1 - 20 of 31 Posts
Hi I am selling my GSX1400 Fighter (132BHP @ the Wheel) to buy a 910R, am i doing the right thing, also there is aStarfighter in my local shop, he says prob the last one around, is it worth the extra £1800 to get one, I dont think so
My vote: yes and yes. Certainly the right trade...and I think Starfighter looks great and will hold its value better too. Maybe I say that because they are not available in the US. I thought the premium was greater. But the 910r will not disappoint either. Good luck...and welcome :)
HHMMM obviously I am biased, I love the Brutale. But a GSX1400 is a very different beast (heavier, gruntier, comfier etc). The Brutale is pure raw race machine without all the sportbike ergos shortcomings. I would suggest you have a ride. If you want something more brutal and sporty then yes it is the machine. They can even do the occasional tour. Oh and did i mention they were designed by a genius and are a work of art etc etc...
As for the Starfighter it was a design excercise, if that doesn't turn you on, then the R is still sensational. Once you get this idea in your head though it is hard to shake...these machines will hit your emotional nerves like your GSX never will.
Good luck.
If you can,have a demo ride on the Brutale and decide on your own sensations,if not all I can I say to you is:buy it!Stay with R not Starfighter(£1800 for a different painting and seat are too much)you can use this money for something else like steering damper and anti slippery clutch.
Hi all, I have taken a 910 out for a ride, sounded awsome, looks fantastic, the only thing i was worried obout was the size, my 14 is huge, i have attached a picture hopefully.
King of the Sink
First - I hope we can welcome you to the club soon!
Second - I'm 6'4", and I don't have any problem with the 910R. The layout is a little different - especially the pegs - so I'd second what everyone else is saying about taking it for a ride first. I'd encourage you to remember that even if you think it's a little idiosyncratic, you'll get used to it and the 910R is worth every cent in terms of what it's like to ride.
NO DOUBT..... :drummer:
STARFIGHTER
:smoking:
Here is some more "little" painting differences:
BRUTALE STARFIGHTER "R"
MOTORE: SERIE SPECIALE ELABORATA SU BASE BRUTALE 910 R
motore con condotti lucidati - 144 cv all'albero con collettore fornito in dotazione
GRAFICA: verniciatura artigianale colore nero lucido, grigio opaco con dettagli rossi
sella pilota in pelle colore nero e grigio con cucitura rossa
sella passeggero in pelle colore nero
coperchio testata colore rosso
trattamento di finitura superficiale titanium applicato alla base inferiore di sterzo, forcellone, piastre telaio e contrappesi manubrio.
contagiri con nuova scala numerica e logo Brutale
IMPIANTO DI SCARICO: collettore completo in acciaio inox ed eprom dedicata fornito a corredo
CERCHI: cerchi forgiati in lega di alluminio superlight Brembo con razze a Y e profilo rosso
ANTERIORE: 3,50" x 17" POSTERIORE: 6,00" X 17"
IMPIANTO FRENANTE: ANTERIORE: a doppio disco flottante Ø 320 mm. con fascia frenante in acciaio e flangia in alluminio + pinza freno radiale a 4 pistoncini Ø 34 - Brembo
POSTERIORE: a disco in acciaio Ø 210 mm. + pinza freno a 4 pistoncini Ø 25,4 mm Brembo
SOSPENSIONI: ANTERIORE: forcella oleodinamica a steli rovesciati dotata di sistema di regolazione esterno del freno in estensione, in compressione e del precarico molla steli Ø 50 mm. con trattamento al carbonitruro di titanio con numero veicolo
POSTERIORE: tipo progressiva, monoammortizzatore regolabile in estensione, in compressione (alta velocità/bassa velocità) e nel precarico molla
IMPIANTO DI ALLARME: la moto è dotata di impianto di allarme dedicato
ACCESSORI: tappo benzina in alluminio ricavato dal pieno
coppia di tamponi protezione telaio in alluminio ricavati dal pieno
SERIE LIMITATA: 99 esemplari
certificato serie limitata e ovale in argento per la testa di sterzo con numero veicolo e nome possessore
:banghead:
... and same in english: :stickpoke
ENGINE: LIMITED EDITION MADE FROM BRUTALE 910 R
engine with polished ducts - 144 hp with the manifolds supplied with the bike
GRAPHICS: hand made painting colour bright black, matt grey with red details
leather rider seat colour black and grey with red stiching
leather passenger seat colour black
red engine head cover
titanium surface finish treatment applied to the following parts: lower triple clamp, swingarm, frame plates and handlebar balance weight
speed indicator with MV logo
EXHAUST EQUIPMENT: steel complete manifolds with specific eprom supplied with the bike
RIMS: Brembo superlight black wheels with red profile and Y shaped spokes
FRONT: 3,50" x 17" REAR: 6,00" X 17"
BRAKING SYSTEM: FRONT: double floating disc with Ø 320 mm. with steel braking and aluminium flange radial-type brake caliper with 4 pistons Ø 34 - Brembo
REAR: single steel disc with Ø 210 mm. + brake calyper with 4 pistons Ø 25,4 mm Brembo
SUSPENSIONS: FRONT: "UPSIDE-DOWN" telescopic hydaulic fork with rebount-compression damping and spring preload adjustment rod Ø 50 mm. with carbonitriding treatment with the number of the bike
REAR: progressive, single shock absorber with rebound and compression (high speed / Low speed) damping and spring preload
ALARM: the bike is supplied with specific alarm
ACCESSORIES: machined aluminium frame protections
machined aluminium fuel tank cap
LIMITED EDITION: 99 bikes
limited edition certificate with silver oval plaque with the name of the customer and the number of the bike
and few carbon part....
CARBON COMPONENTS: front mudguard partially painted
SBK upper and lower chain guard
starfighter left and right air box side panels
starfighter cover for instrument pack
starfighter tail piece
cover for ignition unit
left and right rear cylinders covers
left and right side panels for fuel tank
oil radiator guard
starfighter left and right front frame panels
left and right upper radiator guards
left and right lateral radiator protections
left and right footrest guards
upper and lower exhaust guards
rear mudguard
plate support
:yo: :moped:
I have ridden one and found the foot pegs a bit small, but i am sure i will get used to it, cheers for your replys
Mike,do you think that a different painted tank fuel,few carbon accessories,a different seat and a silver plate justify the price of the Starfighter?The important things of the bike are the same:engine,suspensions,rims and the headers-midpipe kit.
Personally I think the ONLY way one can justify the price of a MV period is the desire to have something different! ALL motorcycles have the important things.
Any justification other than "because I want it" is pure rationalization. No matter what the cost it's cheaper than a shrink. :))
Tom
Discussion Starter #16
isnt the list you have done for the Starfighter Titanium?, not the standard Starfighter, i thought it was basicaly a different paint job and red rims
Ambassador / 007 , , Waiting for new bike
Starfighter
Ok ragazzi ora parlo in Italiano,perchè questo post mi interessa...
Ok ok,la 910R è fantastica ed è simile alla Starfighter....Si fa per dire!!!tutto cio' che MIKE21 ha scritto è verissimo,ci sono tante differenze "nascoste",che non si vedono.
Poi ragazzi,la starfighter è stata prodotta in 23 esemplari per la TITANIUM e 99 esemplari per la "mia" in onore al 23° stormo della base NATO di PISIGNANO A Cervia.La Starfighter è la sorella minore della F4 VELTRO.
La grafica del serbatoio è incredibile!Con tutti gli strumenti degli arereoplani,poi,99 esemplari al MONDO non è poco!!!!!
Quando poi decidete di venderla,sara' piu facile guadagnarci sopra,perchè NON CE NE SONO IN GIRO!!!
Esempio:la mia ex GLADIO 750S full optionals la pagai in contanti 17.800 euro,l'ho permutata con MOTO TRIOSCHI a 18.000 euro!!E' rimasta nel negozio 2 GIORNI SOLO prima di essere venduta!!
Insomma,Io voto per la STARFIGHTER anche se costasse 10.000 euro in piu' della R!!! :) :)
Pier Luigi
Never pay again for live sex! | Hot girls doing naughty stuff for free! | Chat for free!
Hi dave!
If you take any brutale or any mv agusta you have made an exellent choice.When i was buying a new bike,i was asking 910 R..I already had ordered the 910 R then my dealer called me if i was intrested in Starfighter Titanium...
After one minute of thinking i ordered it!!! It was very expensive but in that case i didnt want to loose the opportunity to have one jewel of motorbikes..Now i have one of these 23 bikes designed by a genius...I know that most of them is owned by collectors and they stay in garage .....but i enjoy every second when riding it!!!!! :king: It`s allways your own decision which bike you buy but starfighter is an opportunity.1800 more is worth every cent(MY OPINION)!!!
What ever you choose you get just what you want.Good luck and enjoy riding ....... :smoking: :wave:
Regards Mike21
1 - 20 of 31 Posts
