Dorman makes them...a search on Amazon (or Google) will find you some. Your local auto parts store should be able to help. That's where I got mine.
Couple of things: First, when ordering or searching for parts, accuracy is key. If you are seeking the RIGHT side fuel injection line, then you want part number 8000A4887; if you are seeking the LEFT line, then you want part number 8000A4886. By convention.
Those gray fittings are made by a company called John Guest. They are unavailable.
If you need to make up new hoses, then you need J30R14 spec Fuel injection line, a new CPC fitting for the Fuel Pump end of the line and a Dorman 800-185 connector to replace the John Guest fitting.
Amazon.com: Dorman 800-185 Quick Connector 5/16 In. Steel To 8mm Nylon 180, 2 Pack : Automotive
Buy Dorman 800-185 Quick Connector 5/16 In. Steel To 8mm Nylon 180, 2 Pack: Fittings - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
