I have ordered a arrow thunder for my 910R, not sure why just thought i would have a change
it hase the race cans and link pipe and epram upgrade
Will i have to do anything else?
is there any benifit with the arrow
You will have to shorten the midpipe otherwise it will stick out too far.
You don't HAVE to, but most do because it looks better.
Hi it arrived yesterday but did not come with the link pipe, so i have now ordered that, if you cut down the link pipe does that remove the ring for the fixing spring?
Yes. You will have to grind or cut off the ring for the spring. I left mine off, on two different bikes, and have had no problem. You could just move it forward too. It is only a small piece of metal tacked to the midpipe.
