1 - 3 of 3 Posts
Hi i know its here some where but cant find it ,are the air intake panels an easy job to do to replace with carbon,any one point me in the direction of removal and fitting thanks.
Same as the S:three small phillips heads UNDER the tank. You can either pull the tank all the way off (the sensible way) or lift it partially and wedge it up and do your deed. Remember, those fuel connectors love to leak so if you do it the latter way make sure you are not stressing them by tilting the tank too far up.
I don't think they are philips, I believe they were a small offisize HEX like 2.5 or 4mm? I don't remember the exact size but they were HEX on the bikes I've seen. Only the middle one is a bit fiddly.
1 - 3 of 3 Posts
