The bulb behind the tachometer went out the other day. I pulled the dash off and took it apart. I removed the bulb only to find that it is an LED bulb. Does anyone know where to acquire an LED bulb for the tachometer or at least maybe have a part number.
Billy
Looking at the blurry profile pic, I think the previous owner might have put in. Iirc my F4 of the same era uses a T10 wedge bulb, filament style. Not led. If you put your year and model in your signature, I'm sure more people will be able to help.
Thanks for letting me know that your F4 uses a filament stye T10 bulb.
Billy
Billy
According to the parts diagram, both our bikes use the same bulbs. This image is for your 06 910S.
I believe it is a 5watt bulb, I switched the regular to a white LED a long time ago, got mine at local electronic parts store.
Thanks for the info. I think I found an white LED replacement on Amazon.
Billy
Reactions: Skrecov
I received my LED dash bulbs from Amazon today and installed the bulb. The bright white LED bulb really makes the tachometer pop.
