I never had a problem with my 1000R Rob, sure it got to 106ish maybe a degree higher but I never saw 110c, now, fast forward to an R1 and they don't put the fans on until 106c and back off at 103c.Probably because it wasn't overheating. Running hot and overheating are two different things. If the overtemp warning was taken away would the owners think it was overheating? of all the overheating bikes out there how many puked coolant? I took my bike out today, 103 degrees Fahrenheit ambient temperature. Hottest i saw the display was 209 degrees f. The difference between a real problem and a perceived problem is perception. If you remove the visual indicator warning you is it still a problem? Or if there isn't a sign warning you is it really a problem?
Naaaa, Mike's not like that....he's only saying it in jest.yet another "my s1000rr is better than everything else" reply
101 posts already.....buy an MV or f##k offseems as though it is abnormal to have a bike that does not run hot these days. Seems some people are even having issues with the new beemer (not trying to start anything, just saying). So how does the heat compare to a duc?
PS...next time I'll be sure to add smiley faces to everything to make everything right in the world....![]()
Mine too.see normally I would be offended, but that little smiley brightened my day![]()
Best part of you ran down yo mama's legLove the simley face it does just kinda mellow things out, like....
You are all loads that should have been swallowed
Now normally that statement should offend you.....but it just cannot now as I have ended the statement with not one but 10.....yes doudle digit smilely faces.
Have a great fuckin day you a-holes
yet again the power of the smiley
Best part of you ran down yo mama's leg![]()
Bite me.![]()
:laughing: Mine toosee normally I would be offended, but that little smiley brightened my day![]()
Juuust kiddin'
