I had a little leakage in the right front caliper, so I decided to make maintenance in front brakes.
I dismantled both calipers, and first surprise, seals were not the same as the originals supplied by the UK owners club. They seemed to be O-Rings.
Both bleeders were damaged, and it was very difficult to work with them.
But, the biggest problem, the left caliper is imposible to bleed, because it seems to be plugged. I have tried with brake cleaner, thinner, compressed air... and no success.
Anyone knows how is the connection between the bleeding point and the caliper? I can't see any hole.
Any ideas to unblock this point?
With time, I have got good braking feeling, but I would like to solve this problem for next maintenances.
(I have translated a lot of words with google, so probably some words are not the best; I hope you understand the post)
Hi Gafas.
Scarb calipers have a small ball bearing under the bleed nipple.
This can get stuck (making it impossible to bleed that caliper) and can be very difficult to remove. A bit of heat and tapping the caliper when it is upside down may help. It is best to replace this ball with a new one as they rust.
All the best.
Dorian.
Thanks Dorian,
I have already removed the ball bearing, but the connection between the bleeder zone and the caliper seems to be blogged. And I am not able to discover where the hole is, in order to clean it.
Thank you very much Dorian.
Now I understand what I was seeing inside, it was the second ball. Anyway, it should be completelly blocked, I used compressed air and it satyed in place.
Now brakes are working fairly good, I will try on next maintenance.
