Hi guys new to all this, so sorry if this topic done to death. Have had a bit of a dig around but can't find exact info I need. I am thinking from my reading of previous threads that my 2002 Australian delivery 750s has no cat converter in its mid pipe is this correct. Also am currently looking at a set of Silmoto carbon slip on cans noticed a bit of info around but not much detail any advice re fittment or need to rejig the ECU cheers.
Yup your right our bikes were produced pre cat regulations thankfully.
The aftermarket pipes are a straight fit, just remove old ones and fit the new ones. I'd check with who your getting the pipes off to confirm they come with a new ecu chip too, this seems to be the norm with aftermarket pipes.
Your Silmoto pipes will look and sound tip top, be sue to post a sound bite when youv fitted them.
If you don't get a chip with the pipes you could consider a PCIII set up with a custom map to get the best out of the set up.
