1 - 9 of 9 Posts
Ok. There are a lot of people who have issue with the inconsistent and surge motor at 5K and below and the heat problem below 3K. I finally track down a MV engineer and consulted him about the problem. He looked puzzled at me and asked why was I lugging the motor so low and slow, it is not a diesel motor.
He then promptly turned around, hopped on his RD 350 and sped off.
Ride it like a 'Due Tempi' and you will get it.
Tree
I will have to agree with the MV Engineer in one way. Yes, if you ride the stripes off of it, it is a pleasure to ride. No doubt about it. But that kind of riding is pretty much track only, unless you don't value your life all that much when riding on the street.
With regards to "in traffic / city street riding", everyone here will pretty much agree that below 5k the MV doesn't do much other than surge, hesitate, or what ever else you like to call bad fueling / timing / advance, etc.
Less we all forgo the toasted nut analogies due to the crazy high engine temps at low speed.
It would just be nice to ride the MV any way we want, and not have a sweat soaked ass while doing so.
My MV is smooth throughout the rev range. On and off throttle and low rpms might be snatchy but a careful right hand and that problem gets alleviated. No flat spots no nothing. Pulls like a freight train.
Thank You!!
Yes. If your wrist is limp, you are going to have a struggle controlling it below 5k. This is an all effort, all focus motorcycle. I think the F3 was getting the same bad press about low down fueling. I think they developed it with one intent, THEN tried to have it meet some street needs. Yes. There are bikes out there with good down low fueling/rideability, but those builders aren't addressing the same crowd.
Whiners
Wanna-be's
Get some tension in your wrist and stop blaming the builders.
Tree
6k all day
Whiners
Wanna-be's
Tree
6k all day
Its no so much that I blame the builders, it is definitely a focused bike, and should be ridden as such. I love riding the bike 6k+ all day!
The only issue as you say is the "limp wrist". 100% true!
But after a few hundred miles of California coastal twisties at 50 - 100km/h, with numb fingers, and tiredness sets in, it can get to be a little annoying having to baby the throttle so much.
The electronics today definitely have the capability to make the bike more ride-able down low if the engineers so choose to spend the time getting it right. If the Jap bikes, and Duc's can do it, so can MV. Somewhere along the line, they just choose not to do so.
Mine´s not giving any particular snatchy fuelling, but maybe because I have the comp. ECU. Before buying this one, I tried one that was just like it comes from the shop, and it was snatchy, yes. Still, it convinced me straight away to buy the one I have now!! :mouthwate
Also, we get used to it and it´s not a problem anymore, isn´t it? :yo:
Today, temperature outside was around 38ºC, and on the traffic light I easily got to 106ºC (well, not me, her!) but now I stopped worrying too much - as long as it doesn´t start blinking, I´m fine with that. I´m sure you transmit your worryness to the bike and she gets nervous about it and heats up! :naughty::naughty:
Agreed, but I am a big advocate of non-nanny electronic motorsports
But that is just me, being stuck in the wrong era:)
TreeMV
I had all these years the MV Corse RG3 ECU, so the 5K RPM surge was cured but not solved. Lately I fitted an PC properly mapped. Much, much better (OK not like a V2, but better).
I fitted also the water pump impeller upgrade from MV. Huge improvement, from 114C down to 97C, now in summer down town Athens. You notice it from the cooling fans too, they are working almost never.
I have tried also the impeller marketed from Design Corse, little difference. If yes, then the one from MV.
Found a pic of the dyno graph of my Senna. Thought I would share it on this thread. I don't know how to read graphs that well and this one only showed the hp. Wish they had put the torque on there as well. I have the race ecu and I guess the tech was able to modify some things here and there...his words. Feels quite smooth to me every single time I ride. Feels a bit scary in fact lol. Still not used to how brutal the bike can be :laughing:
1 - 9 of 9 Posts
