1 - 13 of 13 Posts
Hello,
I have been driving my mv agusta 350b electronica for a while, and it was driving like a dream. Until suddenly my ignition stopped. Now the bike runs idling, but when i open the throttle the ignition just cuts out. I tested every part of the electronic ignition and it seems to work, but i don't have an electric diagram. Can someone help me with electric diagram for the 350b electronica sport? Or has someone encountered this problem already and knows how to fix it?
Greets Michiel! (sorry for my bad english)
Salut l'ami
Maybe this diagram help you ...
Are you sur that your problem come from ignition. Had you have a look at your carburators ?
Bien Cordialement
Xavier
Thank you for the diagram.
I checked the carbs and they work fine. also the strength of the spark is strong, actually very strong. And the timing of the igniotion is fine too. But the ignition just stops random when I open the throttle...
More simple for me in French. Sorry for Anglophones ...
Désolé, j'ai justement modifié au mieux le schéma avant de le mettre sur ces pages. L'original est quasi illisible
Si tout est ok mais avec une panne intermittente, contrôle les bobines, les fils HT, la résistance des cabochons de bougies, et mets des bougies neuves
Contrôle également que tu n'as pas un fils qui te créé cette panne aléatoire. Mal sertie, cuite, sèche
Courage ! ;)
Xavier
I'm sorry to keep asking all these questions, but is it possible that this electric diagram isn't from a 350b electronica? some wire's are different. The key switch/ignition switch is different connected. The bike I have is a mv agusta 350b electronica from 1975. Do you know maybe if it can be another electric diagram?
The problem is a real mistery to me, I tested everything, all the things u mentioned, and everything seems to work fine. But when i start it and open the throttle the ignition just cuts out most of the times.
Best Regards,
Michiel
Best Regards,
Michiel
It's not I had the same problem. Dorian sent me a pdf of the right one I'll see if I ca find it
Hi,
Couple of thoughts; When you testes all the ign. components were you able to test them at speed? I'd focus on what elements change at revs, e.g. capacitors, diodes, the distributor / advance mechanism itself... Don't know that bike very much.
Second, Check the carb chokes. Although it seems unlikely from the description of your investigation the symptoms sound like a case of non-seated enrichener seats. Even something as freakish as a cable snagging or ???
Good luck and let us know what you find.
-Danny
It was indeed a combination of cables with bad connections, but i needed to electrical diagram to know which cables it could be. Thanks for the help guys!
1 - 13 of 13 Posts
