Does anyone have the OEM Specifications for the minimum thickness of the brake pads (Friction Material thickness preferably, but total thickness would do) for the Scarab brake calipers.
I also need the OEM spec for the minimum thickness of the brake discs.
The info is required as part of the process to get the bike properly registered for road use. Its also the final peice of the puzzle required to satisfy all the red tape.
Any help would be appreciated - thanks
John.
The factory never actualy listed this info so i cant help with anything in writing.
I can measure a new pad and disc if that will help.
Dorian.
I have a brand new set in the packet (Surflex) - pad total is 8 mm - friction material 6mm
Disc thickness - 5mm
Perhaps you can compare these to Dorian's measurements & with 2 sets of corresponding figures you would obviously have a definitive & conclusive result.
Good luck :)
Brand new pads (Surflex) and discs.
Pads the same measurements as Robs.
Discs 5.7mm. I would imagine a min thickness recomendation of approx 4.5mm going from other manufactures spec.
Dorian.
Thanks guys - much appreciated
