I changed my clutch fluid in last May and have driven now c.a 2500 km. Using (Brembo) DOT4 brake fluid according to manual recommendation.
The fresh brake/clutch fluid has light yellowish color and now I have noticed that color has changed to very dark/black within couple months. I had earlier Brutale 750 and never experienced this kind of color change. Anyone had similar experiences? Possible reasons for this appearance?
My bike is Turismo Veloce 2016.
That is simply and indication of wear particles in the system. Ducati Monsters are notorious for quick brake fluid discoloration. Just do a fluid change.
The clutch fluid also gets a steady dose of heat from the engine which discolors it. Brakes get less constant heat.
Thank you gents for quick answers. Yes, I have changed fresh clutch fluid now and will follow if fast discoloring continues.
