There is a superveloce coming up for auction, but it is a statutory write off, so it cant be registered (until I find a way...).
Are there similiar MV frames that the parts from the Superveloce will bolt onto? Or is it a frame all on its own? Or I wonder if MV would sell me a replacement frame???
Thanks! Greg
Is the frame bent, or just cosmetically damaged???
Yes, MV will sell you a frame.
It's based on the F3 but since the SV has different plastics it would have different mounting tabs I would assume.
Sent from my Armor 9 using Tapatalk
Reactions: esq'z me
Discussion Starter · #4 ·
ITs just been under water, no issues with the frame. But, here in Australia, because the bike has been labelled statutory writeoff (for financial reasons) the frame number cant be re-registered. Easiest to find another frame and hang the oem in the shed until something changes....
That's a shame. The frame is sealed so no water can get in to cause rust. Sounds like you should turn it into a track bike if you can't register it.
Wouldn't the VIN be attached to the frame? So a new VIN# would be a different motorcycle?
