They too don’t list anything for the 2017-2022 B3’s.The other option for the triple cylinder MV is Rapid Bike. Similar in function to the PC, but aimed more at Euro bikes. Comes in two versions, Evo and Race.
jetprime is about the only option I found that lists one for the 2017 800. But I’ve been talked into getting the stick ecu flashed instead.??
JetPrime Programmable Control Unit
Memjet EVO Power Module
Thanks mate. I wasn’t aware of that.They too don’t list anything for the 2017-2022 B3’s.
I too have found that model previously. Dynojet refuses to say if it will work with the 2017 model. No other info out there on it.Found this web site and seller in Washington. They list Power Commander V for some MV Agustas.
Not sure if they still have them, but on their web site: Last year application is 2014 ??
Dynojet Power Commander V For MV Agusta - Bayside
Shop Dynojet Power Commander V for MV Agusta at Bayside Performance. Canada's number 1 online source for motorcycle parts and accessories.www.baysideperformance.com
Mine is a 2017. They went from silver engine to black engine. Not sure what if anything changed on the electronics side. But I would imagine injectors and ecu could be different. I’ve got nothing to compare to.What changed in 2015 ? if the ECU and number of injectors are the same it should work. With proper tuning of course.
Did you ask Bayside??
That was quite a few years ago. I think they just didn't have enough of a market for the MVs to make development of wiring and maps worth while.Maybe somehow this comes into play:
