2016 B4 Brutale 920 Wiring diagram needed - Headlight suddenly stopped working
2K views 8 replies 4 participants last post by  K33MVA
#1 ·
I'm reasonably new to this whole forum thingy and can't seem to find a decent wiring diagram for my 920. I expect you're all tired of hearing/reading this type of request but i am a newbie so has anyone got one or can point me in the right direction to get one please.
Cheers in advance.....
#2 ·
Not tired of this type of request at all. There were very few B4 920s made and the manual seems to be a bit of a unicorn.
The wiring diagram was supplied with the Owner's Manual if you happen to have that piece of kit.
The most reasonable advice I can give is that it is very similar to the 990 and that wiring diagram may help.
I assume you searched our library and found nothing there.
#3 ·
Ive been on a bit of a mission today as my headlight suddenly stopped working. I wanted more light from the headlight so have purchaced a reasonably decent H4 Led, put it in, it glowed but it didn't work. I then put the original bulb back and it didn't work....... I then tested them both on a 12v battery and they work perfectly but not when fitted in to the headlamp unit itself and plugged in. I pulled all the fuses and relays and they all work, checked all the wiring point to point and that all has continuity as it should so I can only think that the switchgear has gone on me. I took that off to test and I can't test that properly as to be honest it's stumped me a little. The horn & indicators work as they should but I ain't spending £125+shipping from Italy for a new one just to see if it is that so i think i'm going to have to bang it in the shop and get them to look it. 😤 If it's gone it's gone but i NEED to know. I can still ride her during the day but being in the northern hemisphere it gets dark at 16:30 at the moment so can't really go too far....... I'd rather suss the issue myself but she has me stumpted at the mo......
#4 ·
The fact that the new bulb glowed and then after swapping back the original nothing works tells me you have a high resistance in the wiring. Since the only things disturbed was the headlight bulb connector and/or the headlight to harness connector that is where I would look.
Not much to it. No computer circuitry, no ECM.
The wiring schematic for the lights will be the same as the other Brutales of the year model.
#5 ·
Thanks. I don't want to sound dumb or want to seem ungrateful for your reply but why would that prevent the the original halogen bulb working again? If the halogen bulb had blown, i then took it out and relpaced like for like it should just work, no?? So to me the LED bulb i put in has done something to the lighting circuit somewhere to prevent the halogen one working again .... ???
#6 ·
The halogen bulb doesn’t work anymore due to the bad connection created when swapping in the new bulb. Look at all the wires and connectors you disturbed. especially grounds.
#9 ·
Sussed......! Thanks for all your suggestions and help on this peeps.... Eventually i've found some time to get back to this issue & I found a cable just under the rear fuses that had the insulation worn away by abrasion and had been shorting out on the relay frame..! Taped it up..... 'et voila'..... I now have LED front lights...!
