Does anyone know the header length of 2015 F4 header pipe length? Also need the mid pipe length aswell? Thanks
there is no mid pipe, only headers (inc cat) finishes just before the foot peg, and then the end can (inc exhaust valve) I can measure to night if you want. Pre 2010, I think had a mid pipe
If you could please that would be awsum! Could you measure the length upto the cat. And then from start of cat till end can please cheers
been busy, but here it is, I could'nt remember what you wanted when I was in the workshop so measures a few extra bits.
Based on cylinder 2.
Cylinder exit to O2 sensor: 666 mm
Cylinder exit to Start of CAT: 753 mm
Cylinder exit to End of CAT: 835 mm
Cylinder exit to End Can Joint: 925 mm
Cylinder exit to Exhaust Valve: 1020 mm
Cylinder exit to Start of 'end can' under seat: 1470 mm
Cylinder exit to centre of exit of 'cylinder 4' pipe: 1985 mm
Cylinder exit to centre of exit of 'cylinder 2' pipe: 2100 mm
