My bike arrived with a BS battery and BS battery charger. Zero instructions both in MV instruction/service and charger guides.
Is there a connector I can plug the charger to and not have to take the battery out?
Otherwise can just I plug the charger's red crocodile pin to + and - somewhere on frame? Will that screw something up?
Thanks in advance.
And if not. Yes, you can hook the red alligator clamp to + on the battery and negative to any solid mount on the frame. Even the engine block.
@Tony F: Of course the battery charger has a connection plug. The process is outlined very nicely in the manual for your bike. Check the top of each maintenance section to figure out how to download your manual.
