Ladies,
Has anyone replaced worked on a 2014 1090 ggenerator/alternator? A mates just bought one and it's only putting out 12.5v. Donsey, I downloaded the manual and it mentions everything bar the generator. How to remove the starter motor is the closest I got.
I'll do all the tests but would like to know how to get to the generator. Doesn't look as tight as on the older models. Any info appreciated.
Deano
Regulator ?
Ladies,
Deano
Deano,
Are you sure your bike hasn't got a separate Regulator ? Be worth checking before pulling the generator itself from the bike.
atb
joe
Joe,
Yeah, I'm going to check that first plus all connections, plugs etc. Not my bike and only has 5000kms up. Just can't find any info in the manuals. On ours it's a major fuck around to get the alternator out but there seems more room on the newer models and a change to a stator. The manual also refers to a 'charging fuse'. Do you you think you can track that fucker down anywhere in a manual? Not keen on the changes and quality of the 2010+ models. Cheap and nasty, no offnce to my mate.
Deano
I'll have a look at the wiring diagram for you later today....
Joe,
Deano
Have a look closely and you'll see one of these I'm sure ! Incidentally it appears to be the same part number as for F4s of the same years..which figures.
So a bit easier that chomping out the alternator !
joe
Thanks Joe, got it. Tracked it down on StarTwins site. Seem to be a pretty common part, Yamaha etc. still like to check generator output, connections etc. before he lashes out.
Deano
Deano;
If you have a stator you check it on the bike UNPLUGGED from the R & R.....
at a specific RPM using a meter set to AC Volts.....its actually 3 tests, between the pins
1-2,1-3 and 2-3 then check for continuity to ground on all 3
Good Luck
:popcorn:
