Hello MV Fans,
I was doing a coolant flush myself on my motorcycle. I have drained the coolant through the lowest bleed point.
My question was is it ok to just add coolant in the overflow tank as the radiator drain plug is not easily accessible. Usually on my other motorcycles, I add the coolant through radiator plug and then overflow tank.
Please suggest me the correct procedure. I tried to search on the forum but could not get a correct answer.
Regards
Did you search the manual?
Welcome to the family @sajmani ..... i'm not sure how you were able to post in this section without first introducing yourself in the "New Members" section...but you did !!
Please take a moment to add your location on the planet to your profile. TOOLS > USER CP > Edit Profile.
